Please, is there any additional configuration or particularity besides CS384334 to establish OPC UA communication between KepServer6EX and FTView SE? When I use the KepServer EnterpriseV5.21 version the communication works, but with KepServer6EX it doesn't work. Thank you.
@AA_10676196
There are no known issues connecting FTView SE with KEPServerEX v6. Are you receiving any errors in the KEPServerEX Event log? I recommend making the initial connection with security set to "None" on both the Client and Server side to rule out any certificate issues. You can add in the security certificates after the initial connection has been proven to be successful.
*Chris
