Fanuc CRX Robot I/O addressing
RP_9796666
3-Newcomer
I have used KepServEX for many years without issue - but running the latest version for some reason the I/O addressing is backwards. Digital Inputs are controlled with %Q - does anyone know why this is occuring?
Greetings,
For more than a decade, that code has remained unchanged. Is it conceivable that there is a mix-up on the controller? We would advise you to use an integrator to check at the device side.
Mohit
Greetings,
Mohit
