Has anyone been able to figure out the address for program header?
The driver supports 'cnc_exeprgname_Name' which I believe you are referring to as the "program header". Please take a look at the knowledge base article in the following link which covers the addressing and KEPServedrEX versioning required to access the address.
*Chris
*Chris
