Hi Team,
We have Fanuc molding presses that we want to collect molding data from using OPC UA through the Linki 2 opc server (it is a fanuc software that acts as an opc server amongst other functionalities) But it uses euromap 77 standard and Event based data reading, not subscribe.
https://forum.inductiveautomation.com/t/fanuc-linki-2-euromap-77/90995
https://www.fanuc.eu/hu/en/iot-solutions/roboshot-linki2
In addition, what is the event base data reading. because in our kepware it is come up with exception and poll based.
https://www.ptc.com/en/support/article/CS397586
https://community.ptc.com/t5/Kepware/Euromap-77-and-OPC-UA-client/td-p/943756
Hello! Kepware UA products currently do not support all aspects of the Euromap77 standard. We do not yet support UA Events, nor do we support some of the custom Euromap77 data types defined in the specification.
What is your data destination? Our closest delivery timeframe for support of UA Events will be through our OPC UA aggregation server, UA Gateway. This product brokers UA clients to UA servers, aggregating, optimizing and securing UA traffic. It would NOT allow you to "convert" Euromap77 into some other messaging protocol like MQTT/JSON or HTTP however if your data destination was actually an OPC UA client application using Kepware as a UA broker or Gateway, I can follow-up with more specific release timing.
Thanks for your interest!
Sam
Sam
Hello @DM_IND_2024,
It looks like you have a response from a community member. If it helped you answer your question please mark the reply as the Accepted Solution.
Community Moderation Team.
