Our project is considering using KEPServer but I still don't know the process to bring KEPServer from development environment to real use. Please let me know what documents I should look for and where to find this answer. Thank you.
Some useful resources:
for further information, our project will using PLC of Mitsubishi and using Mitsubishi Enthernet driver.
Here is a link to the PTC resource page which also offers some insight:
I also recommend opening a support ticket with the Kepware team who have a dedicated pre-sales team to assist you with all your architecture questions. Here is a link to the login page where a ticket can be opened:
*Chris
Hello @HuyenDuong,
Please check if this link helps?
And if you found the correct link and it helped to answer your question, please document it by replying to this topic and mark it as the Accepted Solution.
But I am replying to raise awareness. Hopefully, another community member will be able to help.
Community Moderation Team.
