Inside Mitsubishi M80 CNC controller, one Q series PLC is used.
Inside Mitsubishi M70 CNC controller, one QnA series PLC is used.
Then I setup Kepware configuration and PLC program under the help of Mitsubishi Ethernet Driver Help, there have some contents about Q and QnA series PLC, but I can't connect to M80 and M70 controller successfully.
So I want to confirm if Mitsubishi M80 and M70 CNC controller can integrate with Kepware directly?
Unfortunately, Kepware does not currently have a solution for communicating with M80/M70 series directly. An alternative solution would be to use a Q Series PLC as a gateway to the M80/M70 series devices. Please submit a case as described in the following link; if you would like to see if the functionality of a direct connection can be added to future releases of KEPServerEX:
https://www.ptc.com/en/support/article/CS295047
*Chris
*Chris
Thank you for your information.
