I am reaching out to address an ongoing issue I have encountered with OPC UA tags in my system. Despite correct configuration on the client side and the camera software visibly indicating alarms, these are not reflected in the client’s system, suggesting a possible interruption in data transmission between our camera software (OPC DA standard), KepwareEX 6.16 (OPC UA standard), and the client’s software.
Problem Description:
Questions and Assistance Required:
Your expertise and any additional insights you could provide would be invaluable as I aim to resolve these project issue and ensure reliable alarm transmission across my systems.
Thank you for your help.
Hi @LD_11905868,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Thanks for using the Community!
Best regards,
Catalina
PTC Community Moderator
Hi Catalina,
Thank you for highlighting my post and for the suggestions! I'll consider adding screenshots to provide clearer context and enhance the query.
Appreciate your help!
Best regards,
Leo
@VladimirN @ScottInTexas I see that you are the top solution authors, Can you maybe help or do you know someone who can help?
I'm sorry. I am unable to provide any guidance for this issue. I do not use OPC UA.
