I am using PTC-Kepware evaluation copy to generate OPCUA Simulated data and it's working fine for customer demos. Many customer demands MODBUS RTU / TCP Simulated data from PTC-Kepware tool.
1. Is PTC-Kepware support MODBUS simulation?
2. Where can I get training videos of Kepware tools?
Hello @SW_10703260,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
