Dear,
I am evaluating Universal Device Driver (UDD) for one on-going project using socket TCP communication. I can find some examples of the profile files from following github link.
https://github.com/PTCInc/Universal-Device-Driver-Examples
I also studied the video tutorial from following Youtube post (Getting Started with the Universal Device Driver). But the example (openweathermap api) doesn't work.
https://www.youtube.com/watch?v=RGWTfE3Yg4Y&t=5s
So can I find other detail tutorial, then I can build up an end-to-end example?
You can find documents and release notes here: https://www.ptc.com/en/store/kepware/drivers/universal-device-driver
Dear VladimirN,
Thank you so much for the answer. Actually I am finding a code example and corresponding tutorial. Then I can follow the tutorial to practice.
The UDD examples provided in the GitHub link are the only examples Kepware has at the present. I recommend opening a support ticket with the Kepware team to provided more pointed assistance. The Kepware support team has the capacity to provide both Pre and Post sales guidance. Here is a link to the login page to open a support ticket:
https://my.kepware.com/s/login/
*Chris
