Is there any idea about the following error code : HR=C004800E?
BRangi
Just facing an error "Error LinkMaster\Runtime Asynchronous 2.0 write complete notification for item 'STN0159\Yokogawa.ExaopcDACS1.1\FCS0201!SIEMENS_5.DT15' failed (HR=C004800E)."
What does it means?  Data Quality is Good but continues logs are updating in Linkmaster event log.
Linkmaster Latest Version installed.
Best Regards,
Bhadresh Rangi
rajskumar
(To:BRangi)
I am not sure, but searching past cases indicates the following:
OPC error code 0xC004800E suggests that the item in question is not writeable.
Please verify if you have the appropriate permissions and ensure that the tags are writable. Please Confirm if this issue is the cause of the error?
rajskumar
(To:BRangi)
