Hi PTC Community,
I'm currently facing a peculiar issue in KepserverEX 6.15 while working with a specific .opf configuration file that includes a datalogger setup.
Thank you for further clarification. Since you are just opening the old .opf file to see the settings, there is no need to perform runtime connect and update.
I am not sure what is causing the "Regenerate Column Mapping Rules" settings to change randomly after opening the file each time.
As this is affecting only 4 settings of Yes/No under "Regenerate Column Mapping Rules," I suggest taking a screenshot of this setting from the old file and applying it to the new project.
For detailed analysis, you can submit a support ticket and provide the old .opf file so Tech Support can check what is happening.
I checked it on 6.17 and did not observe the issue. I also reviewed the release notes and found that no fixes were made between 6.15 and 6.17 for a similar issue.
Here are a few things you can check:
If the issue persists, I recommend opening a support ticket with the Kepware Technical Support team. Tech support may need to check a particular .opf file.
Here is a link to the My Kepware login page where a ticket can be submitted:
Hi rajskumar,
thanks for the fast reply. The issue is that the .opf file I'm using is not modified. I just use it to create a new one using some identical configurations on the migration process. The only thing I do with the .opf is open it to look at its configuration.
1. No changes are made. The new .opf I am creating is modified normally.
2. All Datalogger groups are disabled. Still, the issue is in the .opf I use to copy from.
3. Should I have Runtime / Runtime clients disabled in the old configuration when opening it? When asked for updating the runtime, what should I do?
