KEPServerEX: "The Installer was unable to find required root certificates"
MW_10097593
2-Explorer
when trying to install KEPServerEX I'm getting the error:
Do you know below mentioned instructions on installing root certificates incl. which are the relevant ones?
2021-10-27 22_49_56-2021-10-27 18_52_39-frasappprodis01 - Remotedesktopverbindung.png ‎- Fotos.png
Marco
Read this article - "Installation fails because of missing root certificates in PTC Kepware Products": https://www.ptc.com/en/support/article/CS321323
7 REPLIES 7
Yes, this worked !
Here the direct link to the article referenced in the one you provided:
https://www.ptc.com/en/support/article/CS292168
many thanks
Marco
You're welcome.
For me it doesn't work. I installed certificates like described in this article but still same info: "The Installer was unable to find required root certificates". I am trying to install this version: KEPServerEX6-6.15.132.0.exe. Where could be a problem?
Well, Copy => Paste with the article above. Help mentioned here on support page doesn't work at all on my system. Any other ideas to solve this issue?
@MW_10097593 @JM_10724634 ,
My name is Chris and I'm the Kepware Community Agent. Kepware has had a lot of success resolving this issue through the use of the following knowledge base article (particularly the KEPServerEX 6.8 / TKS 6.8 and all newer releases instructions) which JM_10724634 may have referenced:
Article - CS321323 - Installation fails because of missing root certificates in PTC Kepware Products
If the article instructions do not resolve the install issue, I recommend opening a support ticket with the Kepware Support Team to see if a remote session could be facilitated to assist with the resolution.  Here is a link to the My Kepware page where a support ticket can be opened:
Log In | My Kepware
*Chris
Hi Chris,
Thank you for your reply. But as I mentioned in my post and reacted to previous post. Your solution with installing root certificated DOESN'T work. So any other solution how to instal KEPServerEX6-6.15.132.0.exe ? I can provide you remote session, so you can try install it on your own. Thanks, Jiri
