KEPWARE MQTT SERVER
LE_11058071
2-Explorer
KEPWARE MQTT SERVER
Good Morning,
I am using THINGWORX KEPWARE SERVER 6 for the first time. I need help please
I need to interact with a command box using the MQTT server on Kepware but I don't know how to configure or what is required to establish communication.
My goal is to be sure that I can communicate with other applications using the MQTT broker on KEPWARE.
THANKS.
Take a look:
In this video, we will show you how to use the MQTT Client Driver in KEPServerEX to connect with MQTT compatible industrial devices and brokers like CloudMQTT Broker Services. We will walk you through the steps to configure the MQTT Client Driver, connect to the broker, and set up data tags to ...
Take a look:
Hello @LE_11058071,
It looks like you have a response from a community member. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
