When attempting to activate my Kepserver Licence by loading a Request File to generate a Response File, I get the following error and no response file is generated.
Error: - callout failed with reason - Error processed during activation: 6011:Attribute Trusted Host Entity is required in the definition of {1}.
This is after repairing a Trusted Storage error by following CS313362 and CS293892. Installation is now appearing as "new" with no activated license, and license key has been reset on MyKepware and is showing 1 activation available. No issues generating the request file. No Internet connection is available from the machine.
** FIXED **
This error appears it may be version related.
Remote server had KepserverEx v 6.4.321.0 installed. I was unable to update this myself due to system security (no ftp permissions).
I was able to have the customer's IT upload the install pack for v 6.12, and proceeded to do a complete uninstall of 6.4, deleted the Flexnet files, and then a clean install of v 6.12. I was immediately able to successfully active the license.
*Note - I am unsure if the deletion of the Flexnet files was required in this instance, but completed this step as a precautionary measure.
Read the following article - "How to request License Activation ID reset in PTC Kepware Products": https://www.ptc.com/en/support/article/cs303223
We need license number and request file for investigation which should be done with support case. Can you open a technical support case by steps of below article?
Kepware Case C16529759.
CS293892 does not fix the 6011 error upon activation request.
** FIXED **
