Greetings,
I know nothing about kepware, other than it gets data from my PLCs for me. i dont setup the topics, i pretty much never get on the server. not my job.
However, i am having trouble getting info from an oracle database, after having what i think i needed installed on the server. There were some OPCDB addons or something like that, as well as upgrading oracle on the server from v12 to 18 maybe? I got the user and password from our IT folks.
I can connect to and see the columns i want to pull the data from, however when i try to actually pull data, i get the error attached. i asked our IT folks and they said i had the correct login info to read from the oracle database and they suggested i get on here...
I program PLCs, so i may not understand what you say, but hopefully i can show it to someone who will know what to do with it
Greetings @TM_11420364 ,
I hope you are doing absolutely fine. Could you please confirm if you have followed the steps below?
Mohit
Yes, i saw that when i was browsing support articles, we did try to change that setting with no luck.
