Kepware Filter
VN_9969195
Kepware Filter
Hi Support,
 I am trying to filter out tags during an import. Could you please provide some examples of how the leaf filtering works. I have tried different itereations and get the same results eavh time.
aservetas
(To:VN_9969195)
Using the Simdemo project installed by default, I added an OPC DA Client driver channel to look at tags that included the word 'Byte' as shown here:
When browsing to add tags for import using the leaf filter, type in the filter you wish to apply first, then expand the node tree and it should only display tags that match the filter you have entered,
-Andy
8 REPLIES 8
aservetas
(To:VladimirN)
Wildcards can be used before and after the text entered.  Also, the leaf filter is case sensitive.
-Andy
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
VN_9969195
(To:aservetas)
Hi Andy,
I tried the following filter, i still get all the results.
Can you tell me what im doing wrong?
VN_9969195
(To:VN_9969195)
Any ideas or suggestions?
aservetas
(To:VN_9969195)
-Andy
Greetings,
Does this Post answers your question?  For the benefit of other Community Members who may have the same question, please designate it as the Accepted Solution.
If this response did not answer your question, please post your current status so we can continue supporting you.
Thanks for using the PTC Community!
Mohit
VN_9969195
(To:MRohilla)
Mohit,
Is there a way to filter for devices instead of the leafs. So using the above Simdemo project, i would like to see only folders that have device name containing "Registers"
Greetings,
While it may seem challenging, this approach will give you a comprehensive view of the entire server project structure.
Mohit
