Hi there,
Is there any licensing or performance limitation regarding
Nahuel
Hi @nahuel.
Please provide more information regarding the use case. We're not sure what type of gateway product you're running.
--Sharon
Hi @slangley!
I am using Kepware's built-in MQTT Client and the goal is to connect the MQTT client to some cloud provider (ex, Azure) using a one-to-one topology. That is, using one MQTT Client per Asset / PLC.
With that context in mind, I wanted to know the limitations stated in the first post.
FYI, this is my Kepware version
Regards!
Nahuel
