Hi friends i need support to recuperate kepware licence that i have no acces more, to the machine originally installed. Need i open especial ticket to this resolution? Can you explain how i open this especial ticket?
Tks
Greetings,
In order for us to assist with that, you would need to submit a ticket through the My Kepware portal. You can select 'submit a support ticket' and it will be routed appropriately and we can assist.
Kind Regards,
Andrew Black
Greetings,
Kind Regards,
Andrew Black
Hi @DiegoTavares.
Were you able to obtain support for your issues through a case? If so, posting the solution here for other community members would be greatly appreciated.
Regards.
--Sharon
