License Status - Broken Binding
JS_10696320
2-Explorer
Hey guys,
we received a message on our server with Broken Binding.
Has anyone here received this message before who can guide us to resolve it?
Cheers
Jhonathan Dias
ntripathi
(To:JS_10696320)
Hi @JS_10696320
Did you buy it from Kepware or from our channel partner? Renewal will be done accordingly.
5 REPLIES 5
ntripathi
(To:JS_10696320)
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS278989
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
Hi, first of all thanks for the reply.
I've tried this procedure before, but as our license has already expired support I can't do much with Kepware's direct support.
I will continue to research as I look into the issue of renewing support.
ntripathi
(To:JS_10696320)
Greeting @JS_10696320
To renew the support end date of the license ID you would need to submit a ticket through the My Kepware portal. You can select 'submit a support ticket' and it will be routed appropriately and we can assist.
I understood. In that case we have to hire a new support correct? Is the proposal for the value of this renewal made directly by Kepware or by a partner company? We are located in Brazil.
While we haven't made our application, it's still stopped.
ntripathi
(To:JS_10696320)
Hi @JS_10696320
