MQTT connection is getting disconnecting and connecting a very short interval.
vgarg
8-Gravel
Description: I am using Thingworx Industrial Connectivity(Kepware) 8.3.65. Here it is connected with MQTT server by MQTT driver. But the it is getting disconnecting and connecting a very short interval.
abhkumar
(To:vgarg)
Hi@vgarg
Could you please share kepware logs , Application logs and communication and configuration logs files from  \ThingworxStorage\logs folder from the time when issue occurred.
Abhishek
