Hi, I am having a Manufacturing Suite License and it was working great till some days before when I tried to configure Alarms and Event in Kepware Ex 6.14.
Just after trial, I removed the configuration in Alarms and Events tab, but still I am getting the message pop up: One or more feature is time limited...
I have disconnected and Re-Initialized, even restored old configuration backup, but still it keeps on Popping up...
Greetings,
I would request you kindly perform the below steps and check.
Greetings,
The OPC AE plugin requires a separate license that is not included in the Manufacturing Suite.
https://www.ptc.com/en/store/kepware/advanced-plug-ins/alarms-events
Best regards,
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
