Mitsubishi FX-1N/2N PLC connectivity with KepserverEX
- May 20, 2024
- 2 replies
- 1758 views
We have connected Mitsubishi FX1N, 2N, 3G and Omron PLC to the KEPServerEX using respective drivers through ethernet encapsulation mode and all PLCs are communicating with KEPServerEX as expected. However, we are facing the issue in Mitsubishi FX1N PLC when connected to KEPServerEX using the driver Mitsubishi FX through physical medium as ethernet encapsulation. Ethernet encapsulation is performed through MOXA Nport (TCP server Mode).
Observation
1) The communication between KEPServerEX and FX1N PLC is success and can be able to read PLC register data as expected.
2) But whenever PLC get power restarted, observed abnormal/random values in PLC registers (Only in FX1N PLC).
3) If KEPServerEX connection removed then no such observations noticed in FX1N PLC
