An application protocol such as OPC UA provides specific services and relies on TCP to ensure reliable delivery. Therefore, I recommend checking TCP socket connectivity from the client PC first, using link as a prerequisite for validating the network connection.
After that, please verify the client-side configuration using link.
Note -If you are prompted to log in to view the complete article, you can use your MyKepware login credentials. Thanks
