Network adapter is not shown. So getting BAD in client file.
Following action also done but still not showing it.
Start the server_config.exe as Administrator
Go to KEPServerEX 6\server_config.exe > right click Properties > Compatibility > Change Settings for all users > Run this program as administrator > Enable.
Please suggest what to do for Quality as good in client file
Articles:
Articles:
Hello @PM_11420518,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
