We need to acquire a licence for an OPC UA Client driver. We have two Kepserver systems(licensed with SNMP Suite) and have set up OPC tunnelling between the two systems, but the feature OPC UA Client is time limited on one of the systems. What is the right software suite to purchase. We are looking at purchasing the OPC Connectivity Suite. will this be adequate for the Kepserver system setup with the OPC UA Client driver configuration.
Greetings @Akeem_2024
In summary, the OPC Connectivity Suite should be adequate for your Kepserver system setup with the OPC UA Client driver configuration. It provides the necessary tools for seamless communication between your Kepserver instances and other OPC UA servers.
For detailed information and pricing, I recommend opening a support ticket with the Kepware team. Here is a link to the mykepware login page where a ticket can submitted:
https://my.kepware.com/s/login/
