Hello Everybody,
I'm trying to connect Kepware OPC-UA Client driver to remote OPC-UA Server to read about 50K tags.
It looks like the communication is too slow and other client, that connects to Kepware and read these tags experience read failures and doesn't read all of them and about 50% of tags signed with bad values. Event log of Kepware filled with lot of events like "The subscription id is not valid.",Status code = 0X80280000.(At the attached picture)
Is it anywhere recommendations about good configuration practice on OPC-UA Client driver?
And what are the sizing recommendations (amount of tags, devices and channels) for Kepware server?
Thanks a lot
When using the OPC Client Drivers within the Kepware project, each channel is a unique connection to the server and subsequently each device created under the channel is a unique OPC group to the target server
Let me know if you have any other questions or concerns.Thanks
Hello @BT_9980021,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
