Problem With OPC UA Server Port 49320
GD_9146088
Hello everybody. We have a server with KepServerEX  (6.12.361.0) and Ignition (7.9.21)  installed as client of Kepware. In the OPC UA Configuration, the server endpoint is setted as default : opc.tcp://127.0.0.1:49320.
Everything was working fine until last week. but now Ignition is in error becuase can not connect to the OPC server (kepware) . I noticed that even if the KepServerEx service is running, I can not see the port 49320 in Listening state ( I used the command C:\ ....\netstat -aon). I installed a Kepware on my laptop and when the service is running I can find this row (with the same command ...\netstat -aon):
TCP      127.0.0.1:49320       0.0.0.0:0      LISTENING       15340
I tried to change the port number in the server but nothing changes.
Other informations:
The device connected to Kepware (channels) communicate perfectly.
The server is not connected to the internet, the firewall is disabled, OS is Windows Server 2019.
Using a tool the check the port status I see the port 49320 closed, not in error. The other ports are working well.
Do you have any suggestions?
Thank you in advance
Guido De Biase
rajskumar
(To:rajskumar)
Also observe Event log messages and see if you are getting any such errors
  • In the server Event Log, it shows:
    • Socket error occurred connecting. | Error = 10061, Details = 'No connection could be made because the target machine actively refused it.'
    • Socket error occurred sending data. Error 10054, Details= 'An existing connection was forcibly closed by the remote host.'
    • Socket error occurred connecting. | Error = 10038, Details = 'An operation was attempted on something that is not a socket.'
If this is the case, refer below article for troubleshooting
https://www.ptc.com/en/support/article/CS299048
rajskumar
(To:GD_9146088)
Kepware Runtime request the OS to open a listening socket on the target OPC UA port (typically 49320),
Have you checked if IT policies in place that is preventing this?
Please stop/start the runtime and check if it is works?
If the issue persist; I recommend opening a support ticket with the Kepware Technical Support team. Here is a link to the my kepware login page where a ticket can submitted:
https://my.kepware.com/s/login/
rajskumar
(To:rajskumar)
