Problem With OPC UA Server Port 49320
Hello everybody. We have a server with KepServerEX (6.12.361.0) and Ignition (7.9.21) installed as client of Kepware. In the OPC UA Configuration, the server endpoint is setted as default : opc.tcp://127.0.0.1:49320.
Everything was working fine until last week. but now Ignition is in error becuase can not connect to the OPC server (kepware) . I noticed that even if the KepServerEx service is running, I can not see the port 49320 in Listening state ( I used the command C:\ ....\netstat -aon). I installed a Kepware on my laptop and when the service is running I can find this row (with the same command ...\netstat -aon):
TCP 127.0.0.1:49320 0.0.0.0:0 LISTENING 15340
I tried to change the port number in the server but nothing changes.
Other informations:
The device connected to Kepware (channels) communicate perfectly.
The server is not connected to the internet, the firewall is disabled, OS is Windows Server 2019.
Using a tool the check the port status I see the port 49320 closed, not in error. The other ports are working well.
Do you have any suggestions?
Thank you in advance
Guido De Biase
