Processor , memory , HDD OIDs changing by themselves in Windows upon reboot
AS_9884785
3-Newcomer
I am collecting snmp data trough Keepware snmp suite and converting data to OPC server for my SCADA system. I see that i often loose memory , CPU and HDD reading after  a reboot. I then ca see that OID address has changed. is there a setting or a way to detect this in keepware snmp suite software ?
Thank you for your question.
I encourage you to bring more details and context to your initial inquiery. For example, screenshots are useful to better understand what you are trying to do and will also increase your chance to receive meaningful help from other Community members.
Andra
