Hello, i have a problem with connecting to a S5-PLC from Siemens. I want to use WinCC V8.1 to connect with a OPC server in this case KepwareEX. Now i want to know if it is even possible that the OPC server can connect with PROFIBUS FMS wich the S5-PLC uses.
Kind regards Wesley
