Is it possible to generate a random Boolean using the Simulator Drive?
I would like to Simulate a Tag that's value will swap between True/False.
Tim
Hey Tim,
To create a Random Boolean simulator tag, use User(frequency,0,0,1,0,1,1,1,0,0,0) function where frequency is ms of tag update.
Hope this helps.
Chris
Hey Tim,
Hope this helps.
Chris
Works! Thanks!
