I am attempting to import tags for a newly added Device. PLC is a Siemens S7-315-2 PN/DP. The PLC project was originally created in Netherlands with comments etc in a mix of English and Dutch language. The PC's at my location are all localised for English only.
Kepware Error messages:
Step 7 language file failed to open. ¦OS error = C:\ProgramData\Kepware\KEPServerEX\V6\1640396820\Global\Language was not found.'.
A required code page is unavailable on this machine. Tag generation may fail or tag names and descriptions may not appear as expected.¦Required code page = 0.
Article - "Tag Import from the Step 7 project fails with error: "Step 7 language file failed to open" in PTC Kepware PRoducets": https://www.ptc.com/en/support/article/CS293239
