TIA Portal Exporter does not support TIA v17
MS_9518598
Hello all,
I tried to test KepwareEX 6.11 and find that TIA portal explorer hails that openness is not installed at the begining of explorer installation. I hope its only question of proper testing at this moment. Is there any workaround how to overcome that message and try it?
Thanks for answer.
MS
Have a look at the following articles:
Any plans to support V17?
Maybe you do not need the exporter anymore. The Siemens S7 Plus driver (https://www.kepware.com/en-us/products/kepserverex/drivers/siemens-s7-plus-ethernet/) provides the following feature:
  • Online auto-tag generation directly from devices that have symbolic names attached, is accessible and marked visible to the HMI
