TOYO connection through Euromap63
AT_10876945
About connecting Toyo IMM, when I read document of Euromap63, there is a block diagram that display the connection which tells Machine in Plant floor --> Share Folder--> OPC Server.
Please verify me if OPC Server right here is Kepware or maybe some other OPC Server?
Besides, I want to ask anyone who has already connected through this way that how the Machine in Plant Floor can attach/export their files to the share folder in order to the response when Kepware gives the request? Will It need to be required extra coding or maybe involved the Toyo IT support to do this? Or need IoT gateway?
@AT_10876945
The "OPC Server" in the diagram would be KEPServerEX.  It would be up to your device to write data to the shared folder and KEPServerEX would read from this folder. You may need to contact the device vendor to see how your specific device performs writes to the shared folder.
*Chris
@AT_10876945
*Chris
