I am having a Datalogger configured in Thingworx Kepware Server.
Already, Log Items are configured there. Now, I would like to add New Log Item but both the options i.e 'New Log Item' and 'New Log Items' are showing disabled (unable to add).
Checked License Utility. It is good.
Hello, Please take a look at the following article as it may help resolve your issue:
Article - CS273673 - Unable to make configuration changes in Configuration Client or Datalogger Plugin in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
