Good day.
I have exactly the same issue but in UDP. and sending data. I need to send two data in an ASCII telegram over UPD IP and UCON just stops sending after 5mn, 1 h, or 1 day or more. Nothing in the logs.
Best regards
Reference topic: https://community.ptc.com/t5/Kepware/UCON-Driver-TCP-IP-Stops-Collecting-Data/m-p/956202#M2072
I found the cause: UCON stops sending the telegrams when I use the "Quick OPC client" (rev 6.10)
Best regards
Best regards
