Unable to get KepServerEX connected to my Mitsubishi FX3U processor using a FX-ENET-ADP. Have tried UDP and TCP with no success. Currently plc setup is UDP,1025,192.168.1.250,1025.
KepserverEX is set to Mitsubishi Ethernet, and UDP, 5000,0 (have tried other combinations)
at this time only attempting to read one tag D250
Have also swapped over to TCP with no success.
Any help appreciated
Thanks, Bob
Take a look - "KepserverEX connect Mitsubishi PLC FX3U guide": https://www.youtube.com/watch?v=ou4Nto1u_dI
this was no help at all, since I had no issue getting KepServerEX working through a serial port.
I have resolved the TCP connection issues, but am still having problems with the UDP for some reason. The plc side is reporting an error 2550 which is basically an ASCII data received error. Manual indicates to change the plc side setup to Binary (which it already is) and fix the data message, which would be the KepServerEX itself. I still believe its some kind of configuration issue on the KepServerEX end. Thanks, Bob
