I need to use Kepware to convert for a unit of measure. That is, if we pack 4 cups on the lines, I want to count the four as one single unit. How can the tool be used to perform the conversion?
You could potentially use KEPServerEX Advanced Tags and the Derived Tag to achieve the functionality you have described. Here is a link to the page in the Advanced Tags manual that covers the Derived tag function:
I recommend opening a support ticket with the Kepware team if you need assistance with your specific architecture. Here is a link to the login page where a support ticket can be opened:
*Chris
