It is about the data rates connection with Thingworx? what is the priority with the data rates of tags?
Article - "Factors affecting the rate at which data is pulled from a KEPServerEX/ThingWorx Kepware Server Tag to a Remotely Bound Property in ThingWorx Platform": https://www.ptc.com/en/support/article/CS313389
Thank you very much, it is really a helpful answer!
You're welcome.
