We need to connect an equipment to KepServer using the protocol ZMQ.
Would it be a solution with KepServerEX?
Thank you
Greetings @DO_10031276
I regret to inform you that unfortunately, KEPServerEX does not support ZMQ. However, If you’re looking for an alternative, KEPServerEX does support MQTT.
Hello @DO_10031276,
It looks like you have a response from a community member. If it answered your question please mark the reply as the Accepted Solution.
Vivek N
Community Moderation Team.
