Here i am facing problem will communicate with kepware and thingworx foundation to binding tags. I am not able to operate the plc from thingworx
Hi @RS_10015366,
There may be two scenarios:
Note: whenever you restart the KepServerEx, you need to save the Remote Thing in Thingworx, if not in the Remote Thing Signals show bad.
Hi @RS_10015366 ,
can you please share application logs from the ThingWorx Storage folder.
Regards
Bhawna
Hi @RS_10015366,
