focus drivers do not load
TO_10703003
6-Contributor
loaded Focus 1/2 libraries to the KEPSeverEX 6
get this message for all the focus drivers
Date Time Level Source Event
6/13/2023 1:14:10 PM Warning KEPServerEX\Configuration Unable to load driver DLL 'C:\Program Files (x86)\Kepware\KEPServerEX 6\drivers\fwlib0DN.dll'. Reason: Version mismatch.
I could use some guidance with this
server problem resolved and up dated Kepware version 6.12 from 6.8
reinstalled the focus drivers and the tags are good.
thanks for the help
10 REPLIES 10
Could you provide your Kepware Version and the Focas DLL version.
Here is a link to a KB, around focas drivers and "dll": https://www.ptc.com/en/support/article/CS281557
kepware ver 6.8
focus 5.8
i also tried an older version
Ok, so could check also the dll version, suppose to be: FWLIB32.DLL (version 1.12.0.2 or later) and FWLIBE1.DLL (version 1.6.0.2 or later)
how do i find the version?
Just right click on you "dll", then select "Properties", and click on "detail" tab (I don't have the Focas "dll", so it's an example in this scree shot)
Fwlib32 version 7.3.0.1
Fwlibe1 version 5.3.0.1
found the files did not load the system32 folder. they will reset the server in 10 minutes
the server did not like that it will not start. IT is working on the issue
thanks for the help
You're Welcome
