kepserver for windows 7
ET_11056550
what kepserver version should i use for windows 7?, i tried to install kepserver 6.15
but it say doesn't support
cmorehead
(To:ET_11056550)
@ET_11056550
Please take a look at the following Kepware article:
Article - CS305196 - Beginning and Ending Operating System Support for KEPServerEX (ptc.com)
It appears Widows 7 was last supported with KEPServerEX version v6.8
*Chris
6 REPLIES 6
You can't use KepServerEX V6, with Windows 7, isn't supported
Try to download KepserverEx V5 from mykepware.com
thanks for the reply, I'll try it.
cmorehead
(To:ET_11056550)
@ET_11056550
*Chris
ET_11056550
(To:cmorehead)
Thank you, for every one that reply my topic, i try every solution on vm just to make sure that kepserver v6.8 and v5 work, before try on the actual machine and it did actually work on windows 7,
Hello @ET_11056550
It looks like you have a response on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
