Hey
I connected a new S7-1200 type controller under the Siemens TCP/IP ETHERNET Driver and I get an error in the event log of
Time limited usage period on feature siemens s7 plus ethernet has expired.
I would love to understand the essence of the error or why it is created? Is the definition not good/accurate or is it an inappropriate type of license?
If the settings are not good / accurate - I would appreciate your help.
Hello @OS_10942037 ,
It looks like either your License is not Valid or License status is not in Good State (Check in License Utility) or You may Activated the Demo License which got expired or Need to check Which license you have activated is valid with driver or not.
Please check. If License is not in Good State in License Utility then kindly open Support Ticket.
For your Reference refer this following Article for more details about Time limited feature: https://www.ptc.com/en/support/article/CS276365
By login to MyKepware, you can Access the Article.
Best Regards,
Bhadresh Rangi
Best Regards,
Bhadresh Rangi
