while configuring kepware to thingworx we are facing error "the connection requires a valid trust store, but the store is empty or invalid."
here is attached snap of property
I have checked application key is valid and having date of expire 2022 We have not configure SSL but still its throwing this error.
Hi Sharon,
Thanks for reply but we have not installed thingworx on SSL .and its fixed authentication type with navigate so definately its not on SSL.
Dhananjay
Hi Sharon,
Thanks for this article I have tried mentioned approches in article but still facing same issue. Is any where in thingworx SSL setting i need to disable i have checked platform.json file but there is no such setting .In integration runtime settings.json having such option but it encrypted. Please help and again we have not establishing SSL connection.
Dhananjay
Hi Dhananjay,
Please try setting disable encryption to 'Yes' . You had set it to No as per the screenshot you had shared in initial post.
Hi @dpchavan.
If one of the previous responses allowed you to find a solution to your problem, please mark the appropriate one as the Accepted Solution for the benefit of others in the community. If you are still having issues, please let us know.
--Sharon
