AppHomePage-extension license
SOLVED
Re: AppHomePage-extension license
Since the same error was displayed, I contributed.
We download necessary files from PTC site.
The environment is used from Remote Desktop from AWS.
1) After installing Thingworx_8_0_1,
Importing ThingworxManufacturingApps - 8.0.0 - 00 - extension - dependencies does not cause problems.
When you import ThingworxManufacturingApps - 8.0.0 - 00 - extension,
As a result, the following error appears.
"AppHomePage-extension is licensed but can not find feature in license.bin file."
2) License is obtained from PTC support site and as described in Installing commentary
I changed the name of the file to license.bin and put it in the ThingworxPlatform folder.
3) When "localhost / Thingworx / FormLogin / Welcome" is executed from the web, the following will be displayed.
"The named organization Welcome does not exist"
The reason is that "Organizaition" does not have "Welcome", so it has not been successfully imported.
4) I also confirmed this community, but it will not be resolved.
https://community.ptc.com/t5/Manufacturing-Apps/AppHomePage-extension-license/m-p/512134#61093
Did you solve with this correct answer?
Is there any other cause.
takashi
Hi Takashi,
Instead of going to the form-login, can you try going to the Factory.Console mashup?
Milan
Highlighted
Hello Milan,
Always thank you for your help.
It will be under evaluation now.
Open "FactoryConsole" from "Thingworx Composer" and execute "View Mashup".
Do you mean to perform many operations from "FactoryConsole"?
If you make a mistake, please point out.
Best regards,
takashi
Hi
PTC.FactoryConsole (as shown above) is the landing page for Factory Solution.By Navigating from this page, you should able to access all the factory apps and its functionalities based on available license.
Varathan
