Asset Advisor OEM Failed to import
vxavier
The error messages is like the image above:
SCO_Common-Extension:8.0.0                    Import Failed: java.lang.NullPointerException
AppHomePage-Extension:8.0.0                    Import Failed: java.lang.NullPointerException
I need some help here. What could possibly be wrong here ? Did Someone face the same issue before?
Thank you,
Vinícius Xavier.
1 ACCEPTED SOLUTION
hrajpal
(To:vxavier)
Hi Vinicius,
Java configuration for tomcat is referring to 1.8.0.121 version of jre which looks good to me.
I would suggest you to restart the server and import the extension again.
If the issue still persists , i would recommend you to redeploy the Thingworx.war again.
Himesh Rajpal
10 REPLIES 10
mthakker
6-Contributor
(To:vxavier)
Hey Vinicius,
Looks like you don't have the requisite JRE/JDK installed.  Can you verify that you have JDK 8 Update 111 installed?
Milan
vxavier
(To:mthakker)
Yes, I have JDK 8 Update 111 installed.
hrajpal
(To:vxavier)
Greetings Vinicius
Checked the extensions for SCO_Common-Extension:8.0.0, AppHomePage-Extension:8.0.0 and found out that the JDK Version used for Build is 1.8.0_121.
Could you please try the import again by upgrading the Java version on your system.
Himesh Rajpal
vxavier
(To:hrajpal)
The same problem again after the java update.
hrajpal
(To:vxavier)
Hi Vinicius,
Could you please share the java configuration for your tomcat server on which ThingWorx Platform is running ?
It might be pointing to old java version . Need to check that .
Himesh Rajpal
vxavier
(To:hrajpal)
Hi Himesh,
I paid attention on that. Here follows the image.
Vinicius.
hrajpal
(To:vxavier)
Hi Vinicius,
Himesh Rajpal
vxavier
(To:hrajpal)
Hello Himesh,
Redeploy Thingworx.war woked well.
Thank you very much,
Vinicius.
Was there any additional information on log files??
vxavier
(To:vranganathan)
I don't remember very well. But was something about SCO_Common-Extension.
I used a snapchot of the VM, that's why I lost it.
