I want to add asset and line type to create equipment pop up panel as in the attachment.
Also, I want to assign asset detail mashup to each asset or line type.
If possible, let me know the way.
Hi @yonkim,
Yes, you can create custom template as per your requirement. The detailed steps are provided under Adding Custom Subtypes of ThingWorx Apps Customization Guide
Himanshu
Hello Yonkim,
yes, you can add the asset, line type in asset advisor. Kindly refer to this guide for detailed information to create assets, line in asset advisor
Manoj Pathak
Of course, according to the guide, I can add assets or lines. However, I want to add an asset through a predefined asset template. The asset template must have a separate asset detail mash up.
Can I add these asset types(Template)?
Hi @yonkim,
Himanshu
Hi @yonkim ,
Hope you are doing good.
In regard to this post, if the previous response provided you with the guidance you were looking for, please mark it as the Accepted Solution, for the benefit of others who may have the same question.
Himanshu
