I have Thingworx and Kepware installed on the same server, but Remote thing is always disconnected when trying to bing a kepware tag in thingworx via the industrial gaeway
Re: post
Sure you can install KEPServerEX and ThingWorx on single server. On Your Remote Things add a ThingShape 'IndustrialThingShape' and on Properties and Alerts tab set value for property IndustrialThing and select the Thing used to connect between ThingWork and KEPServerEX.
Abhishek
Abhishek
Hi @vigneshmurthy.
To expand on Abhishek's response, while it is possible to run both Kepware and ThingWorx on the same machine, this is not a recommended configuration for a production environment. Over time you may begin to experience performance issues, especially if you are also running the ThingWorx persistence provider on the same machine.
--Sharon
Hi @vigneshmurthy.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
