Can I install the ThingWorx MFG App Express RAM 4 Gb?
SOLVED
Participant
I have only 4 GB Computer RAM. Can I find early version of ThingWorx MFG App Express and continue with my PC or it's impossible?
Tags (1)
Re: Can I install the ThingWorx MFG App Express RAM 4 Gb?
I tried and it doesn't work with 4GB. I have seen even issues with 8GB as well.
Greetings Kate,
I am afraid the recommended Machine Requirement is 16 GB RAM , 4 core CPU and 100 GB Disk Space.
If you go ahead in installation of Manufacturing Apps on machine having 4 GB RAM , you might face some issues which will not help your cause.
Himesh Rajpal
Greetings @Kate
Following up with you on the original question posted here, if any of the responses answered this, please mark the appropriate post with "Accept as Solution" for the benefit of others who may have the same question.
Or, if you are still unresolved on this issue, let us know and we can continue troubleshooting this with you.
Best regards,
Steven M
